メインコンテンツにスキップ
はじめに
If your LG Risio front-facing camera is not functioning, use this guide to replace it.
パーツ
パーツは指定されていません。
  1. Use a plastic opening tool to seperate the back panel from the device. Remove the back panel.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. Place your thumb along the bottom of the battery and pry upwards to remove.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. Using your hand, pick up the midframe to  separate it from the phone.
    • Using your hand, pick up the midframe to separate it from the phone.
    • If the midframe does not want to lift off, go back and repeat step 6.
  7. Unclip the front camera connector from the motherboard and lift it from the frame. Unclip the front camera connector from the motherboard and lift it from the frame.
    • Unclip the front camera connector from the motherboard and lift it from the frame.
終わりに
Amina
メンバー登録日: 2018年02月21日
73 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S4-G6, Thompson Spring 2018 University of North Texas, Team S4-G6, Thompson Spring 2018人のメンバー
UNT-THOMPSON-S18S4G6
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 109
