メインコンテンツにスキップ
LG Rebel Screen Replacement
必要な工具と部品
  1. LG Rebel Screen Replacement, Screen: 手順 1、 1の画像 1
    • Place the plastic opening tool into the indent on the side of the phone and lift the back off the device.
  2. LG Rebel Screen Replacement: 手順 2、 1の画像 1
    • Put the plastic opening tool in at a downward angle and push it up so that the back pops off.
  3. LG Rebel Screen Replacement: 手順 3、 3の画像 1 LG Rebel Screen Replacement: 手順 3、 3の画像 2 LG Rebel Screen Replacement: 手順 3、 3の画像 3
    • Insert the spudger into the small groove under one of the two black pieces.
  4. LG Rebel Screen Replacement: 手順 4、 2の画像 1 LG Rebel Screen Replacement: 手順 4、 2の画像 2
    • Using either your finger or the spudger, gently lift the metal clasps until they are no longer connected to the back of the phone.
  5. LG Rebel Screen Replacement: 手順 5、 2の画像 1 LG Rebel Screen Replacement: 手順 5、 2の画像 2
    • Using the metal spudger, push gently under the edge of the screen. You will hear the sound of the screen disconnecting from the glue.
    • Run the metal spudger around the entire perimeter of the phone , making sure to fully disconnect it from the glue.
  6. LG Rebel Screen Replacement: 手順 6、 1の画像 1
    • Place suction cup on the screen.
    • Gently pull the screen up until it is completely disconnected from the phone.
終わりに
13 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
devan morales
メンバー登録日: 02/08/18
561 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team S16-G2, Nardone Spring 2018 Sam Houston State, Team S16-G2, Nardone Spring 2018人のメンバー
SHSU-NARDONE-S18S16G2
5 メンバー
10のガイドは作成済み
3 件のコメント
Hey! Very helpful guide. I was just wondering if this works with replacing the digitizer and the screen, or is it just the screen? email ellym54@gmail.com, I would really appreciate the help!
Elly Murray - 返信
How do you know if you need to replace the digitizer as well? This Lg Rebel4 was dropped & screen cracked in 2 places however everything still works fine? Im not sure what a digitizer does though. Please help me so i understand because i dont want to mess this up.
Thanks guys
Blackhatchic1@gmail.com
BlackHat Chic - 返信
This is just to replace the glass panel over the actual display/digitizer, is it not?
If this is right, why does one need tom remove the back of the case and “undo the metal clips”?
What about gluing the new screen in? It DOES need glue, does it not? Otherwise, what seals it from the environment?
Mark Wallner - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 32
今までの合計 12,285
