メインコンテンツにスキップ
LG Rebel Rear Camera Replacement
必要な工具と部品
  1. LG Rebel Rear Camera Replacement, Rear Camera: 手順 1、 2の画像 1 LG Rebel Rear Camera Replacement, Rear Camera: 手順 1、 2の画像 2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: 手順 2、 3の画像 1 LG Rebel Rear Camera Replacement: 手順 2、 3の画像 2 LG Rebel Rear Camera Replacement: 手順 2、 3の画像 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: 手順 3、 2の画像 1 LG Rebel Rear Camera Replacement: 手順 3、 2の画像 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: 手順 4、 3の画像 1 LG Rebel Rear Camera Replacement: 手順 4、 3の画像 2 LG Rebel Rear Camera Replacement: 手順 4、 3の画像 3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: 手順 5、 3の画像 1 LG Rebel Rear Camera Replacement: 手順 5、 3の画像 2 LG Rebel Rear Camera Replacement: 手順 5、 3の画像 3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: 手順 6、 2の画像 1 LG Rebel Rear Camera Replacement: 手順 6、 2の画像 2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: 手順 7、 3の画像 1 LG Rebel Rear Camera Replacement: 手順 7、 3の画像 2 LG Rebel Rear Camera Replacement: 手順 7、 3の画像 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: 手順 8、 2の画像 1 LG Rebel Rear Camera Replacement: 手順 8、 2の画像 2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Emma Johnson
メンバー登録日: 02/08/18
184 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team S16-G2, Nardone Spring 2018 Sam Houston State, Team S16-G2, Nardone Spring 2018人のメンバー
SHSU-NARDONE-S18S16G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 7
今までの合計 486
