はじめに
Before continuing, make sure the device is powered down. Also make sure that the battery and back casing are removed.
必要な工具と部品
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
Locate the rear facing camera.
Using the plastic opening tool, pry apart the cable from where it connects to the phone.
2 の人々がこのガイドを完成させました。
