この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Before continuing, make sure the device is powered down.
必要な工具と部品
To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
Use nail to loosen case on all four sides. Once loose, remove back case.
Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
5 の人々がこのガイドを完成させました。
