メインコンテンツにスキップ
LG Realm Motherboard Replacement
必要な工具と部品
  1. LG Realm Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG Realm Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Motherboard Replacement: 手順 2、 1の画像 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Motherboard Replacement, Plastic Midframe: 手順 3、 2の画像 1 LG Realm Motherboard Replacement, Plastic Midframe: 手順 3、 2の画像 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Motherboard Replacement: 手順 4、 1の画像 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Motherboard Replacement, Rear Facing Camera: 手順 5、 1の画像 1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Motherboard Replacement: 手順 6、 1の画像 1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
  7. LG Realm Motherboard Replacement, Front Facing Camera: 手順 7、 1の画像 1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  8. LG Realm Motherboard Replacement: 手順 8、 1の画像 1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
  9. LG Realm Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
  10. LG Realm Motherboard Replacement: 手順 10、 2の画像 1 LG Realm Motherboard Replacement: 手順 10、 2の画像 2
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
  11. LG Realm Motherboard Replacement: 手順 11、 1の画像 1
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
  12. LG Realm Motherboard Replacement: 手順 12、 1の画像 1
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ryan St Martin
メンバー登録日: 03/05/16
785 ポイント
4のガイドは作成済み
チーム
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016人のメンバー
MARS-LAFLEN-S16S1G5
2 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 1,305
