メインコンテンツにスキップ
はじめに
This guide will walk you through the process of replacing the power and volume buttons in an LG Phoenix 2. This guide could be used when the buttons do not respond them being pressed. This guide may also be used when the buttons get stuck.
  1. LG Phoenix 2 Power and volume buttons Replacement, Battery: 手順 1、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement, Battery: 手順 1、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement, Battery: 手順 1、 3の画像 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Power and volume buttons Replacement: 手順 2、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 2、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 2、 3の画像 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: 手順 3、 2の画像 1 LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: 手順 3、 2の画像 2
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Power and volume buttons Replacement: 手順 4、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 4、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 4、 3の画像 3
    • Remove all 9 screws on the back by using a Phillips head #J00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Power and volume buttons Replacement: 手順 5、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 5、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 5、 3の画像 3
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Power and volume buttons Replacement: 手順 6、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 6、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 6、 3の画像 3
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Power and volume buttons Replacement: 手順 7、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 7、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 7、 3の画像 3
    • The buttons are attached with adhesive to both sides of the back shield. To separate the orange cables insert a metallic Spudger underneath and gently pull up.
    • Once the orange part is loose move to the next step.
  8. LG Phoenix 2 Power and volume buttons Replacement: 手順 8、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 8、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 8、 3の画像 3
    • Remove the buttons frame on the back side the shield, by inserting a plastic opening tool underneath the frame.
  9. LG Phoenix 2 Power and volume buttons Replacement: 手順 9、 3の画像 1 LG Phoenix 2 Power and volume buttons Replacement: 手順 9、 3の画像 2 LG Phoenix 2 Power and volume buttons Replacement: 手順 9、 3の画像 3
    • The buttons are attached with adhesive. To separate them from the shield insert a metallic Spudger underneath and gently pull up.
    • Once the part is loose you should be able to pass the backside orange cables through the hole.
終わりに
Esteban Ruibal
メンバー登録日: 2018年02月14日
702 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G2, Eyestone Spring 2018 USF Tampa, Team S2-G2, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 375
