メインコンテンツにスキップ
はじめに
The motherboard is the central hub of communication for all components in a device. If you notice that one or more components are failing are not working in your device, it may be time to replace the motherboard.
This guide shows how to replace the motherboard of the LG Phoenix 2, model LG-K371. A motherboard replacement may be necessary if the phone is not working, is badly damaged, or running very poorly. A motherboard replacement may also be needed if the charge port has worn out and you do not want to solder.
パーツ
パーツは指定されていません。
  1. LG Phoenix 2 Motherboard Replacement, Battery: 手順 1、 3の画像 1 LG Phoenix 2 Motherboard Replacement, Battery: 手順 1、 3の画像 2 LG Phoenix 2 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Motherboard Replacement: 手順 2、 3の画像 1 LG Phoenix 2 Motherboard Replacement: 手順 2、 3の画像 2 LG Phoenix 2 Motherboard Replacement: 手順 2、 3の画像 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Motherboard Replacement, Motherboard: 手順 3、 2の画像 1 LG Phoenix 2 Motherboard Replacement, Motherboard: 手順 3、 2の画像 2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Motherboard Replacement: 手順 4、 2の画像 1 LG Phoenix 2 Motherboard Replacement: 手順 4、 2の画像 2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Motherboard Replacement: 手順 5、 3の画像 1 LG Phoenix 2 Motherboard Replacement: 手順 5、 3の画像 2 LG Phoenix 2 Motherboard Replacement: 手順 5、 3の画像 3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Motherboard Replacement: 手順 6、 3の画像 1 LG Phoenix 2 Motherboard Replacement: 手順 6、 3の画像 2 LG Phoenix 2 Motherboard Replacement: 手順 6、 3の画像 3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
終わりに
4 の人々がこのガイドを完成させました。
Alex Selsley
メンバー登録日: 2019年11月04日
295 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G1, Harley Fall 2019 IUPUI, Team S1-G1, Harley Fall 2019人のメンバー
IUPUI-HARLEY-F19S1G1
3 メンバー
4のガイドは作成済み
コメント1件
Are the LG Phoenix 2 and LG K8 motherboards interchangeable?
Jon Doer - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 340
