メインコンテンツにスキップ
LG Optimus T Camera and Camera Mount Replacement
必要な工具と部品
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: 手順 1、 2の画像 1 LG Optimus T Camera and Camera Mount Replacement, Camera: 手順 1、 2の画像 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: 手順 2、 1の画像 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: 手順 3、 1の画像 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: 手順 4、 2の画像 1 LG Optimus T Camera and Camera Mount Replacement: 手順 4、 2の画像 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: 手順 5、 1の画像 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: 手順 6、 1の画像 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: 手順 7、 2の画像 1 LG Optimus T Camera and Camera Mount Replacement: 手順 7、 2の画像 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
終わりに
作成者
2人の作成者と共同で作成されました。
stacey
メンバー登録日: 02/07/17
219 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017人のメンバー
OSU-WILDER-S17S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 121
