はじめに
For this guide make sure that you have correctly removed the back and the speaker before you begin the guide.
必要な工具と部品
Pry the back panel from the frame of the phone to reveal the motherboard.
Lift the speaker cable off the motherboard.
Lift the motherboard up. It will Still be connected to the frame.
Pry under the camera to lift it off the frame.
There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
The camera should now be entirely separated from the phone.
ある他の人がこのガイドを完成しました。
