はじめに
For this guide make sure that you have correctly removed the back and the speaker before you begin the guide.
パーツ
パーツは必要ありません。
  1. Pry the back panel from the frame of the phone to reveal the motherboard. Pry the back panel from the frame of the phone to reveal the motherboard.
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. Detach the connectors on the motherboard. Detach the connectors on the motherboard. Detach the connectors on the motherboard.
    • Detach the connectors on the motherboard.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Continue to lift the connectors off the motherboard. Continue to lift the connectors off the motherboard. Continue to lift the connectors off the motherboard.
    • Continue to lift the connectors off the motherboard.
  5. Lift the speaker cable off the motherboard. Lift the motherboard up. It will Still be connected to the frame. Lift the motherboard up. It will Still be connected to the frame.
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  6. Pry under the camera to lift it off the frame. There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone. The camera should now be entirely separated from the phone.
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
まとめ
ある他の人がこのガイドを完成しました。
Paul
メンバー登録日: 2014年10月07日
145 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 8-1, Leahy Fall 2014 USF Tampa, Team 8-1, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S8G1
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 905
