はじめに
In order to complete this guide you must have lifted the motherboard from the phone.
パーツ
パーツは必要ありません。
  1. Pry the storage unit off until it comes loose and the motherboard can be lifted from the frame. Pry the storage unit off until it comes loose and the motherboard can be lifted from the frame. Pry the storage unit off until it comes loose and the motherboard can be lifted from the frame.
    • Pry the storage unit off until it comes loose and the motherboard can be lifted from the frame.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Pry the front speaker from the frame until it becomes loose enough to remove. Pry the front speaker from the frame until it becomes loose enough to remove. Pry the front speaker from the frame until it becomes loose enough to remove.
    • Pry the front speaker from the frame until it becomes loose enough to remove.
まとめ
Paul
メンバー登録日: 2014年10月07日
145 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 8-1, Leahy Fall 2014 USF Tampa, Team 8-1, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S8G1
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 778
