はじめに
This is a very easy repair to make. The only precautions are the weakness of the materials. The frame is very narrow around the battery slot and may break if not removed delicately. Removing the antenna requires pulling up on nodes attached to circuit components. Be sure to apply pressure near the nodes to ensure that you do not pull up anything but the antenna.
必要な工具と部品
Begin the process with the device face down to remove the back cover. Remove the battery cover using your hands to access the inside of the phone.
2 の人々がこのガイドを完成させました。
