メインコンテンツにスキップ
LG Optimus L7 P705 Headphone Jack Replacement
必要な工具と部品
  1. LG Optimus L7 P705 Headphone Jack Replacement, Display: 手順 1、 2の画像 1 LG Optimus L7 P705 Headphone Jack Replacement, Display: 手順 1、 2の画像 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Headphone Jack Replacement: 手順 4、 2の画像 1 LG Optimus L7 P705 Headphone Jack Replacement: 手順 4、 2の画像 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Headphone Jack Replacement: 手順 5、 2の画像 1 LG Optimus L7 P705 Headphone Jack Replacement: 手順 5、 2の画像 2
    • Flip over to the face of the device.
    • Lift off glass screen (display).
  6. LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: 手順 6、 2の画像 1 LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: 手順 6、 2の画像 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  7. LG Optimus L7 P705 Headphone Jack Replacement: 手順 7、 1の画像 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  8. LG Optimus L7 P705 Headphone Jack Replacement: 手順 8、 2の画像 1 LG Optimus L7 P705 Headphone Jack Replacement: 手順 8、 2の画像 2
    • Detach the mount including both the SIM card and the motherboard from the device.
  9. LG Optimus L7 P705 Headphone Jack Replacement, Headphone Jack: 手順 9、 1の画像 1
    • Lift off the connector using the plastic spudger.
  10. LG Optimus L7 P705 Headphone Jack Replacement: 手順 10、 1の画像 1
    • Lift the speaker connector using the plastic spudger.
  11. LG Optimus L7 P705 Headphone Jack Replacement: 手順 11、 3の画像 1 LG Optimus L7 P705 Headphone Jack Replacement: 手順 11、 3の画像 2 LG Optimus L7 P705 Headphone Jack Replacement: 手順 11、 3の画像 3
    • Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
    • Lift off the headphone jack connector on the top right using the plastic spudger.
    • Replace the board containing the headphone jack.
終わりに
作成者
3人の作成者と共同で作成されました。
Tianyu Song
メンバー登録日: 01/24/17
107 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-2, Baechle Spring 2017 IUPUI, Team 2-2, Baechle Spring 2017人のメンバー
IUPUI-BAECHLE-S17S2G2
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 397
