メインコンテンツにスキップ
LG Optimus G Pro Midframe Replacement
必要な工具と部品
  1. LG Optimus G Pro Midframe Replacement, Remove Back Cover.: 手順 1、 1の画像 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Midframe Replacement, Remove the Battery.: 手順 2、 1の画像 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
  3. LG Optimus G Pro Midframe Replacement, Screw Removal: 手順 3、 2の画像 1 LG Optimus G Pro Midframe Replacement, Screw Removal: 手順 3、 2の画像 2
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
  4. LG Optimus G Pro Midframe Replacement, Remove Cover: 手順 4、 1の画像 1
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
  5. LG Optimus G Pro Midframe Replacement, Completion: 手順 5、 1の画像 1
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Wesley Pate
メンバー登録日: 09/25/14
1,641 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 15-5, Remmell Fall 2014 USF Tampa, Team 15-5, Remmell Fall 2014人のメンバー
USFT-REMMELL-F14S15G5
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,002
