はじめに
This guide will take you through the process of replacing a dead or dying battery in an LG Optimus F60. This task should take no more than 30 seconds to 1 minute. No tools are required for this task but the small blue opening tool is recommended for ease of use.
必要な工具と部品
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
ある他の人がこのガイドを完成しました。
