メインコンテンツにスキップ
LG Optimus F3 digitizer screen glass replacement
必要な工具と部品
  1. LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: 手順 1、 3の画像 1 LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: 手順 1、 3の画像 2 LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: 手順 1、 3の画像 3
    • Remove Back Cover
    • Remove SDCard (if you have one)
    • Remove SIM Card
    • Remove Battery
  2. LG Optimus F3 digitizer screen glass replacement: 手順 2、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 2、 2の画像 2
    • Remove 10 Philips Head screws
  3. LG Optimus F3 digitizer screen glass replacement: 手順 3、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 3、 2の画像 2
    • Using a pry took, pry the back plate off of the phone. Work your way around, prying the tabs as you come to them.
  4. LG Optimus F3 digitizer screen glass replacement: 手順 4、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 4、 2の画像 2
    • Use pry tool to disconnect camera cable and then remove the camera
  5. LG Optimus F3 digitizer screen glass replacement: 手順 5、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 5、 2の画像 2
    • Use pry tool to disconnect 4 ribbon cables and two antenna wires.
  6. LG Optimus F3 digitizer screen glass replacement: 手順 6、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 6、 2の画像 2
    • Use pry tool to gently remove the logic board.
  7. LG Optimus F3 digitizer screen glass replacement: 手順 7、 2の画像 1 LG Optimus F3 digitizer screen glass replacement: 手順 7、 2の画像 2
    • Use pry tool to remove headphone jack.
  8. LG Optimus F3 digitizer screen glass replacement: 手順 8、 1の画像 1
    • Use the pry tool to pry the front frame off of the main body of the phone.
  9. LG Optimus F3 digitizer screen glass replacement: 手順 9、 1の画像 1
    • Carefully pull the digitizer cable through the slot. There will be a small piece of rubber blocking the opening. You may remove it, or just pull through it.
    • Note: If the slot is not wide enough, make sure that you removed the headphone jack, as described in step 7.
  10. LG Optimus F3 digitizer screen glass replacement: 手順 10、 1の画像 1
    • Use a heat gun or blow dryer to heat up the adhesive holding the glass in the frame. Carefully remove the glass using a pry tool.
    • Clean existing adhesive off of frame, or reuse it if you managed to keep it intact.
    • Apply new adhesive if not reusing existing adhesive.
    • Insert new glass.
    • Ensure that speaker cover at top of phone is in place.
    • Reverse steps to reassemble phone.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Rita Snodgrass
メンバー登録日: 05/17/14
284 ポイント
1ガイドが承認済み
3 件のコメント
I followed the guide, put it back together but it now starts up and only stays up for a bit before reporting a heating issue. It feels hot in the upper left hand corner of the phone as well as the back upper middle.
any thoughts on what I did wrong?
chris baggett - 返信
I did this repair successfully, and linked to an album of photos below. I actually took these photos while putting it back together, but I reversed the order to help with taking it apart.
http://imgur.com/a/sRfRM
There's a couple things to watch out for.
First - there's two versions of the screen for the LG Optimus F3. You either have the (LS720/MS659/VM720) screen, which has rounded corners at the top (like mine), or the (MS659/P659), which has square corners at the top. I bought the wrong one, and cracked it trying to grind the corners off at the top.
You will need to use a heat gun to get the old screen off, and I just used an epoxy to attach the new one.
When reassembling, make sure all of your wires are plugged back in. I missed one, and I was getting no signal. Last thing - make sure you put the main center button in before you snap the front screen assembly to the main phone body.
James - 返信
screen replaced. phone turns on
yet device touch screen does not work.
Anthony - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 9
今までの合計 7,551
