はじめに
Replace digitizer glass in LG Optimus F3 LS720. Also demonstrates almost complete teardown.
必要な工具と部品
Remove Back Cover
Remove SDCard (if you have one)
Remove SIM Card
Remove Battery
4 の人々がこのガイドを完成させました。
3 件のコメント
I followed the guide, put it back together but it now starts up and only stays up for a bit before reporting a heating issue. It feels hot in the upper left hand corner of the phone as well as the back upper middle.
any thoughts on what I did wrong?
I did this repair successfully, and linked to an album of photos below. I actually took these photos while putting it back together, but I reversed the order to help with taking it apart.
There's a couple things to watch out for.
First - there's two versions of the screen for the LG Optimus F3. You either have the (LS720/MS659/VM720) screen, which has rounded corners at the top (like mine), or the (MS659/P659), which has square corners at the top. I bought the wrong one, and cracked it trying to grind the corners off at the top.
You will need to use a heat gun to get the old screen off, and I just used an epoxy to attach the new one.
When reassembling, make sure all of your wires are plugged back in. I missed one, and I was getting no signal. Last thing - make sure you put the main center button in before you snap the front screen assembly to the main phone body.
