メインコンテンツにスキップ
LG Optimus F3 Motherboard Replacement
必要な工具と部品
  1. LG Optimus F3 Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. LG Optimus F3 Motherboard Replacement: 手順 2、 1の画像 1
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. LG Optimus F3 Motherboard Replacement: 手順 3、 1の画像 1
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. LG Optimus F3 Motherboard Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. LG Optimus F3 Motherboard Replacement: 手順 5、 1の画像 1
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. LG Optimus F3 Motherboard Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. LG Optimus F3 Motherboard Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. LG Optimus F3 Motherboard Replacement: 手順 8、 1の画像 1
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. LG Optimus F3 Motherboard Replacement: 手順 9、 1の画像 1
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
終わりに
3 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Battsooj Bayarsaikhan
メンバー登録日: 10/28/15
101 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 622
