メインコンテンツにスキップ
LG Optimus F3 Headphone Jack Replacement
必要な工具と部品
  1. LG Optimus F3 Headphone Jack Replacement, Headphone Jack: 手順 1、 1の画像 1
    • Place your thumb at the bottom of the phone's back where the charging port is located.
    • Gently pull the cover off.
  2. LG Optimus F3 Headphone Jack Replacement: 手順 2、 1の画像 1
    • Using the indent at the bottom of the battery, lift and remove the battery from the phone.
    • Place the battery in a safe location as you will need it for reassembly.
  3. LG Optimus F3 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Remove the ten 1.0 mm screws on the rear case.
    • Place the screws in a safe location as you will need them for reassembly.
  4. LG Optimus F3 Headphone Jack Replacement: 手順 4、 1の画像 1
    • Pry apart the joints to separate the inner case.
    • Insert the opening tool on different locations until the case comes off easily.
    • To avoid damaging the joints of the case do not pry if there is resistance.
  5. LG Optimus F3 Headphone Jack Replacement: 手順 5、 1の画像 1
    • With the inner cover removed, locate your headphone jack.
    • It will be in the upper right corner on the back of the phone.
  6. LG Optimus F3 Headphone Jack Replacement: 手順 6、 1の画像 1
    • Gently grab the headphone jack along the sides with tweezers.
    • Lift the headphone jack out of its socket.
  7. LG Optimus F3 Headphone Jack Replacement: 手順 7、 1の画像 1
    • Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
    • Make sure the dark side without the connectors is face up.
終わりに
To reassemble your device follow these steps in reverse order.
4 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Ryan McDermott
メンバー登録日: 10/28/15
324 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 524
