この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
For trouble with touch feedback or if your screen is cracked and you want to replace it.
必要な工具と部品
Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
Use the PH #000 screwdriver to remove the six screws from the midframe
Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
Use the plastic opening tool to disconnect the small orange tab from the motherboard.
Next disconnect the silver tab slightly above where the orange tab was.
Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
6 の人々がこのガイドを完成させました。
