メインコンテンツにスキップ
LG Optimus Dynamic II L39C Screen Replacement
必要な工具と部品
  1. LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: 手順 1、 2の画像 1 LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: 手順 1、 2の画像 2
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. LG Optimus Dynamic II L39C Screen Replacement, Remove the Battery: 手順 2、 1の画像 1
    • Lift the battery out of the phone and replace with your new one.
    Where can I purchase a new battery for this life's good optimist dynamic II TracFone. Or something compatible
    Carolyn Lane - 返信
  3. LG Optimus Dynamic II L39C Screen Replacement, Remove the SD Card: 手順 3、 1の画像 1
    • Grab the end of the SD Card and pull it out of the phone.
  4. LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: 手順 4、 2の画像 1 LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: 手順 4、 2の画像 2
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: 手順 5、 2の画像 1 LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: 手順 5、 2の画像 2
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 1 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 2 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 3
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. LG Optimus Dynamic II L39C Screen Replacement, Separate the screen and motherboard: 手順 7、 1の画像 1
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Patrick Barron
メンバー登録日: 10/08/14
158 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 14-3, Leahy Fall 2014 USF Tampa, Team 14-3, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S14G3
4 メンバー
3のガイドは作成済み
コメント 1 件
My screen is black but everything else works (even the touch screen -- I can use it to answer calls). I used this guide to change the screens from a working phone - but my screen is still black! Anyone have any ideas?
Jack - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,272
