メインコンテンツにスキップ
はじめに
For changing a broken camera.
パーツ
パーツは指定されていません。
  1. LG Optimus Dynamic II L39C Camera Replacement, Remove the back case: 手順 1、 2の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Remove the back case: 手順 1、 2の画像 2
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. LG Optimus Dynamic II L39C Camera Replacement, Remove the Battery: 手順 2、 1の画像 1
    • Lift the battery out of the phone and replace with your new one.
  3. LG Optimus Dynamic II L39C Camera Replacement, Remove the SD Card: 手順 3、 1の画像 1
    • Grab the end of the SD Card and pull it out of the phone.
  4. LG Optimus Dynamic II L39C Camera Replacement, Remove the screws from the midframe: 手順 4、 2の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Remove the screws from the midframe: 手順 4、 2の画像 2
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. LG Optimus Dynamic II L39C Camera Replacement, Remove the midframe: 手順 5、 2の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Remove the midframe: 手順 5、 2の画像 2
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 2 LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: 手順 6、 3の画像 3
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. LG Optimus Dynamic II L39C Camera Replacement, Separate the screen and motherboard: 手順 7、 1の画像 1
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
  8. LG Optimus Dynamic II L39C Camera Replacement, Detach tabs to separate the camera: 手順 8、 2の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Detach tabs to separate the camera: 手順 8、 2の画像 2
    • Using the spudger, push the black tabs on the sides of the motherboard off carefully.
    • They should snap off easily.
  9. LG Optimus Dynamic II L39C Camera Replacement, Separate orange tab: 手順 9、 1の画像 1
    • Turn the phone over and pull up the orange tab connected to the camera.
  10. LG Optimus Dynamic II L39C Camera Replacement, Separate the camera from the motherboard: 手順 10、 2の画像 1 LG Optimus Dynamic II L39C Camera Replacement, Separate the camera from the motherboard: 手順 10、 2の画像 2
    • You should be able to remove the camera easily with your fingers.
終わりに
ある他の人がこのガイドを完成しました。
Stephanie Reyes
メンバー登録日: 2014年10月08日
138 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 14-3, Leahy Fall 2014 USF Tampa, Team 14-3, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S14G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 390
