必要な工具と部品
With one hand, push the rectangular button located on the back top-side of the phone.
With your other hand, remove the rear cover.
この手順で使用する道具:Tweezers$4.99
Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
もう少しです!
終わりに
