メインコンテンツにスキップ
LG Neon GT 365 Case Replacement
必要な工具と部品
  1. LG Neon GT 365 Case Replacement, Case: 手順 1、 1の画像 1
    • Remove the back cover of the phone by pushing the rectangular button located on the back top-side of the phone.
  2. LG Neon GT 365 Case Replacement: 手順 2、 1の画像 1
    • Use the appropriate screw driver head and remove the six black screws as shown in the picture. A screw may be covered by the slide spring. Move the slide spring to the other side to access that screw.
  3. LG Neon GT 365 Case Replacement: 手順 3、 2の画像 1 LG Neon GT 365 Case Replacement: 手順 3、 2の画像 2
    • Use the plastic opening tool to go around the seem and slowly pull off slide spring assembly.
    • Make sure the ribbon connector does not get caught on other parts of the phone.
  4. LG Neon GT 365 Case Replacement: 手順 4、 1の画像 1
    • Remove the connector ribbon located near the bottom of the phone by pulling gently on the ribbon.
  5. LG Neon GT 365 Case Replacement: 手順 5、 2の画像 1 LG Neon GT 365 Case Replacement: 手順 5、 2の画像 2
    • Carefully, peel off the two green pieces of tape then the gold tape.
  6. LG Neon GT 365 Case Replacement: 手順 6、 1の画像 1
    • Disconnect the copper colored ribbon. It is fine to leave the copper ribbon ttached to the top of the phone.
  7. LG Neon GT 365 Case Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool and go around the silver screen and begin to lift it up.
    • Once the silver screen has been lifted up slightly, slide the bottom half of the green circuit board located below the screen off of the phone. Then continue popping the screen out.
  8. LG Neon GT 365 Case Replacement: 手順 8、 1の画像 1
  9. LG Neon GT 365 Case Replacement: 手順 9、 2の画像 1 LG Neon GT 365 Case Replacement: 手順 9、 2の画像 2
    • Disconnect left side of this ribbon.
    • By disconnecting the left side of that ribbon, the phone's screen can be removed from the outer shell.
  10. LG Neon GT 365 Case Replacement: 手順 10、 1の画像 1
    • Use the plastic opening tool to remove that speaker out of the groove.
    • Use the plastic opening tool to remove the copper colored plate that the speaker and ribbon is attached to out of the phone.
  11. LG Neon GT 365 Case Replacement: 手順 11、 1の画像 1
    • Peel the rubber front keypad out of the case.
  12. LG Neon GT 365 Case Replacement: 手順 12、 1の画像 1
    • At this point, all of removable phone components has been taken out. With the new case, follow the steps in reverse to reassemble.
終わりに
作成者
10人の作成者と共同で作成されました。
kristie
メンバー登録日: 10/23/13
538 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S2G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 307
