Slide the battery cover release towards top of phone.
Place one finger at each side of the battery cover.
Lift and remove the battery cover.
Use the spudger to lift up the rear case from the phone.
Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
Remove the rear case from the device.
Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
Use the spudger to detach the circuit board from the phone.
Open the phone to expose the keypad.
Use your finger to push the keypad from the front towards the circuit board.
Remove the keypad from the phone.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
