メインコンテンツにスキップ
LG Muziq LX570 Camera Replacement
必要な工具と部品
  1. LG Muziq LX570 Camera Replacement, Front Case: 手順 1、 2の画像 1 LG Muziq LX570 Camera Replacement, Front Case: 手順 1、 2の画像 2
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Camera Replacement: 手順 2、 3の画像 1 LG Muziq LX570 Camera Replacement: 手順 2、 3の画像 2 LG Muziq LX570 Camera Replacement: 手順 2、 3の画像 3
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Camera Replacement: 手順 3、 3の画像 1 LG Muziq LX570 Camera Replacement: 手順 3、 3の画像 2 LG Muziq LX570 Camera Replacement: 手順 3、 3の画像 3
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
  4. LG Muziq LX570 Camera Replacement, Camera: 手順 4、 3の画像 1 LG Muziq LX570 Camera Replacement, Camera: 手順 4、 3の画像 2 LG Muziq LX570 Camera Replacement, Camera: 手順 4、 3の画像 3
    • Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
  5. LG Muziq LX570 Camera Replacement: 手順 5、 2の画像 1 LG Muziq LX570 Camera Replacement: 手順 5、 2の画像 2
    • Hold the wiring out of the way and pull up with a spudger behind the camera.
    • The camera unit should come unglued and separate from the phone.
終わりに
作成者
5人の作成者と共同で作成されました。
Braden Burk
メンバー登録日: 01/22/12
1 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G29
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 734
