はじめに
This is a straightforward guide on accessing and removing the LCD for the LG Lucid 4G. Take special care when dealing with the ribbon cables, they can tear easily.
必要な工具と部品
Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
If the camera did not fall off during step five, you must remove it now by gently lifting it. It is attached by a small amount of adhesive and should detach easily.
Gently lift the headphone jack assembly to reveal the touch screen digitizer flex cable.
Release the touch screen digitizer flex cable connector.
The final step is to remove the LCD screen from its housing. Begin by gently peeling the ribbon from the back of the housing.
Once the ribbon is fully detached, carefully feed it through the bottom of the display housing.
Once this is done the LCD screen assembly will have been separated from the phone.
ある他の人がこのガイドを完成しました。
