メインコンテンツにスキップ
LG Lucid 4G LCD Replacement
必要な工具と部品
  1. LG Lucid 4G LCD Replacement, Battery: 手順 1、 3の画像 1 LG Lucid 4G LCD Replacement, Battery: 手順 1、 3の画像 2 LG Lucid 4G LCD Replacement, Battery: 手順 1、 3の画像 3
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G LCD Replacement: 手順 2、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 2、 2の画像 2
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G LCD Replacement: 手順 3、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 3、 2の画像 2
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G LCD Replacement, LCD Assembly: 手順 4、 2の画像 1 LG Lucid 4G LCD Replacement, LCD Assembly: 手順 4、 2の画像 2
    • Begin by removing the seven Phillip's head screws on the back of the phone.
  5. LG Lucid 4G LCD Replacement: 手順 5、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 5、 2の画像 2
    • Use the small notches along the sides of the phone to help you pry the back plate off and help stop the pry tool from slipping.
    • Use the plastic pry tool and begin working your way around the sides of the phone.
    • Some force may be required during this step.
  6. LG Lucid 4G LCD Replacement: 手順 6、 1の画像 1
    • Remove the single Phillip's head screw holding the sim card assembly in place.
  7. LG Lucid 4G LCD Replacement: 手順 7、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 7、 2の画像 2
    • Gently lift the corner of the sim card assembly as shown.
    • The SIM card assembly is still attached to the motherboard via a ribbon cable.
    • Release the press-fit ribbon cable connector by lifting it with a spudger or prying tool.
  8. LG Lucid 4G LCD Replacement: 手順 8、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 8、 2の画像 2
    • Release the five flex connectors on the motherboard.
    • The camera may fall off during this step. That is okay! Set it aside for reassembly.
    • Once all five flex connectors are released, simply lift the motherboard to separate it from the rest of the phone.
  9. LG Lucid 4G LCD Replacement: 手順 9、 1の画像 1
    • If the camera did not fall off during step five, you must remove it now by gently lifting it. It is attached by a small amount of adhesive and should detach easily.
    • Gently lift the headphone jack assembly to reveal the touch screen digitizer flex cable.
    • Release the touch screen digitizer flex cable connector.
  10. LG Lucid 4G LCD Replacement: 手順 10、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 10、 2の画像 2
    • Use a plastic pry tool to begin removing the touch screen assembly.
    • Slide the pry tool along the gap between the touch screen digitizer and the LCD mount to release the connectors.
    • Once the touch screen assembly has been separated, carefully slide the ribbon through the slot in its housing.
    • Caution: Be gentle when separating the two sections along the top of the phone. The ribbon detached in step 6 is attached to the touch screen digitizer and must be carefully fed through the LCD housing to avoid tearing it.
  11. LG Lucid 4G LCD Replacement: 手順 11、 2の画像 1 LG Lucid 4G LCD Replacement: 手順 11、 2の画像 2
    • The final step is to remove the LCD screen from its housing. Begin by gently peeling the ribbon from the back of the housing.
    • Once the ribbon is fully detached, carefully feed it through the bottom of the display housing.
    • Once this is done the LCD screen assembly will have been separated from the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Adam Boeck
メンバー登録日: 02/07/17
133 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017人のメンバー
OSU-WILDER-S17S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 320
