メインコンテンツにスキップ
はじめに
This guide will walk you through the process of replacing a dead or dying battery in your LG Leon LTE.
パーツ
パーツは指定されていません。
  1. Flip phone to the back so you can access back of the phone which holds the battery. Flip phone to the back so you can access back of the phone which holds the battery.
    • Flip phone to the back so you can access back of the phone which holds the battery.
  2. Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the  battery. Some force will be needed
    • Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
    • Some force will be needed
  3. Once the back is removed, you will have access to the battery. Remove the battery and insert a replacement.
    • Once the back is removed, you will have access to the battery. Remove the battery and insert a replacement.
    • The battery is missing in this photo.
終わりに
ある他の人がこのガイドを完成しました。
Geul Kim
メンバー登録日: 2018年01月29日
565 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G3, Bedsole Spring 2018 University of Alabama, Team S1-G3, Bedsole Spring 2018人のメンバー
UA-BEDSOLE-S18S1G3
3 メンバー
10のガイドは作成済み
コメント1件
Could my LG LEON 4G LTE smartphone need a new battery, I have had it for about 7 - 8 years, same original battery. Phone overheats at times, which I let cool. And getting black & white lines vertically on the screen. Also the screen fades out to a white / grey picture. Can the battery be doing this,just.started doing this not long ago PLEASE HELP. Cannot afford a new phone at this time.
Stephen Sylvia - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 644
