メインコンテンツにスキップ
LG LX160 Front Casing Replacement
必要な工具と部品
  1. LG LX160 Front Casing Replacement, Battery: 手順 1、 1の画像 1
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Front Casing Replacement: 手順 2、 1の画像 1
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Front Casing Replacement: 手順 3、 1の画像 1
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Front Casing Replacement, Back Casing: 手順 4、 1の画像 1
    • Now that the battery has been completely removed, hold the phone upright.
    • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
  5. LG LX160 Front Casing Replacement: 手順 5、 1の画像 1
    • Flip the phone with the backside facing up.
    • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
  6. LG LX160 Front Casing Replacement: 手順 6、 1の画像 1
    • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
  7. LG LX160 Front Casing Replacement, Front Casing: 手順 7、 1の画像 1
    • Open your phone to find four small rubber pads at each corner of the screen.
    • Remove each rubber piece and unscrew the screw under the rubber piece. You can see what the screw looks like under the rubber piece in the top right screw.
  8. LG LX160 Front Casing Replacement: 手順 8、 1の画像 1
    • Use a splurger to slide in between the phone and the cover.
  9. LG LX160 Front Casing Replacement: 手順 9、 1の画像 1
    • The cover will be separated from the phone and may be removed.
終わりに
作成者
4人の作成者と共同で作成されました。
Kris Oznowic
メンバー登録日: 01/13/10
1 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S11G2
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,041
