メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will help you replace the logic board.
パーツ
パーツは指定されていません。
  1. Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. Use IPod opening tool to separate back housing.
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. Separate the back housing from the phone.
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. Use a spudger to disconnect antenna wire.
    • Use a spudger to disconnect antenna wire.
  6. Use the IPod opening tool to pop out the logic board.
    • Use the IPod opening tool to pop out the logic board.
  7. Use the IPod opening tool to disconnect the main ribbon.
    • Use the IPod opening tool to disconnect the main ribbon.
  8. Once the ribbon is detached, remove the logic board and replace if necessary.
    • Once the ribbon is detached, remove the logic board and replace if necessary.
終わりに
Joshua Herrmann
メンバー登録日: 2010年04月16日
8 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S6G14
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,166
