メインコンテンツにスキップ
LG L1200 Camera Replacement
必要な工具と部品
  1. LG L1200 Camera Replacement, Inner LCD Screen: 手順 1、 1の画像 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Camera Replacement: 手順 2、 1の画像 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Camera Replacement: 手順 3、 1の画像 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Camera Replacement: 手順 4、 3の画像 1 LG L1200 Camera Replacement: 手順 4、 3の画像 2 LG L1200 Camera Replacement: 手順 4、 3の画像 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Camera Replacement: 手順 5、 2の画像 1 LG L1200 Camera Replacement: 手順 5、 2の画像 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Camera Replacement: 手順 6、 1の画像 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Camera Replacement: 手順 7、 3の画像 1 LG L1200 Camera Replacement: 手順 7、 3の画像 2 LG L1200 Camera Replacement: 手順 7、 3の画像 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Camera Replacement: 手順 8、 3の画像 1 LG L1200 Camera Replacement: 手順 8、 3の画像 2 LG L1200 Camera Replacement: 手順 8、 3の画像 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Camera Replacement: 手順 9、 2の画像 1 LG L1200 Camera Replacement: 手順 9、 2の画像 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Camera Replacement: 手順 10、 2の画像 1 LG L1200 Camera Replacement: 手順 10、 2の画像 2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Camera Replacement, Camera: 手順 11、 1の画像 1
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 Camera Replacement: 手順 12、 2の画像 1 LG L1200 Camera Replacement: 手順 12、 2の画像 2
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
終わりに
作成者
4人の作成者と共同で作成されました。
Joshua Herrmann
メンバー登録日: 04/16/10
8 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S6G14
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,209
