メインコンテンツにスキップ
LG KP100 Screen Replacement
必要な工具と部品
  1. LG KP100 Screen Replacement, Battery: 手順 1、 2の画像 1 LG KP100 Screen Replacement, Battery: 手順 1、 2の画像 2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 Screen Replacement: 手順 2、 2の画像 1 LG KP100 Screen Replacement: 手順 2、 2の画像 2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
  3. LG KP100 Screen Replacement, SIM Card: 手順 3、 3の画像 1 LG KP100 Screen Replacement, SIM Card: 手順 3、 3の画像 2 LG KP100 Screen Replacement, SIM Card: 手順 3、 3の画像 3
    • Remove the SIM card from its housing.
    • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
    • After it is out of the metal housing, it is free to be removed.
  4. LG KP100 Screen Replacement, Motherboard: 手順 4、 1の画像 1
    • Remove the four screws along the edge of the phone body, as shown in the picture to the left.
  5. LG KP100 Screen Replacement: 手順 5、 2の画像 1 LG KP100 Screen Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool, pry open the body of the phone, starting at the bottom of the phone (this tends to be the easiest place to start).
    • Double check to make sure the SIM card is removed from its housing. You will not be able to pry open the body of the phone if the SIM card remains in its housing.
    • Continue by sliding the opening tool around the perimeter of the phone. You should hear multiple clicking sounds as you complete this, indicating the clips are becoming unlatched.
    • This may take a few tries to get correct. Don't give up if it doesn't work the very first time.
  6. LG KP100 Screen Replacement: 手順 6、 3の画像 1 LG KP100 Screen Replacement: 手順 6、 3の画像 2 LG KP100 Screen Replacement: 手順 6、 3の画像 3
    • Put the red casing aside and remove the motherboard from the front casing of the phone by carefully dislodging it from its two clips near the top of the phone.
  7. LG KP100 Screen Replacement, Screen: 手順 7、 2の画像 1 LG KP100 Screen Replacement, Screen: 手順 7、 2の画像 2
    • The upper left corner of the LCD display will be held in place with a small clip. Gently pull the small clip outwards, away from the surface of the motherboard.
    • As shown in the second photo, the lower right hand corner will still be attached to the motherboard. DO NOT try to remove this part yet.
  8. LG KP100 Screen Replacement: 手順 8、 3の画像 1 LG KP100 Screen Replacement: 手順 8、 3の画像 2 LG KP100 Screen Replacement: 手順 8、 3の画像 3
    • The LCD screen is attached by a small ribbon to the motherboard. Gently pull the screen out of the clip it is attached to.
    • Notice: When re-installing a new LCD screen, make sure to prop up the black clip before installing the ribbon cord, as shown in the pictures.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Preston Brown
メンバー登録日: 04/12/12
28 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-20, Amido Spring 2012 Cal Poly, Team 6-20, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S6G20
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,608
