メインコンテンツにスキップ
LG K92 5G Screen Replacement
ビデオの概要
  1. LG K92 5G Screen Replacement, Removing the Back Panel: 手順 1、 1の画像 1
    • Heat the plastic back panel with a heatgun or heating pad.
    • Use a thin metal pry tool or razor to separate the adhesive from the frame, and peel the back cover off.
  2. LG K92 5G Screen Replacement, Remove antenna board and screws: 手順 2、 2の画像 1 LG K92 5G Screen Replacement, Remove antenna board and screws: 手順 2、 2の画像 2
    この手順で使用する道具:
    • Remove 11 same-sized phillips screws from the top antenna panel.
    • Using tweezers, forcefully pop the panel from a safe area up and out of the housing, the lower middle screw hole is a good area to apply leverage.
  3. LG K92 5G Screen Replacement, Remove lower speaker and screws: 手順 3、 2の画像 1 LG K92 5G Screen Replacement, Remove lower speaker and screws: 手順 3、 2の画像 2
    • Remove 8 more identically sized phillips screws from the lower antenna and speaker panel.
    • Pop the lower panel off with tweezers, it should come off relatively easier than the previous panel.
  4. LG K92 5G Screen Replacement, Disconnect almost everything: 手順 4、 1の画像 1
    • Disconnect the battery first!
    • Then disconnect the other main lego style connectors and ribbons. There is no need to disconnect the cameras.
  5. LG K92 5G Screen Replacement, Pull the main logic board out: 手順 5、 1の画像 1
    • Remove the main logic board by pulling from the top and lifting it out.
  6. LG K92 5G Screen Replacement, Remove charging port board: 手順 6、 1の画像 1
    • Remove the single Phillips screw from the charging daughterboard, and pull it out of the frame.
    • (Optional) Leave the antenna lines connected to reduce risk of breaking them.
  7. LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: 手順 7、 2の画像 1 LG K92 5G Screen Replacement, Extract the power button/fingerprint reader: 手順 7、 2の画像 2
    • The power button has a small pressure connected ribbon that is adhered to the frame, carefully pry it up.
    • The fingerprint reader itself is on a separate lego style connector that can then be fished out.
  8. LG K92 5G Screen Replacement, Remove volume and quick button flex: 手順 8、 1の画像 1
    • Gently pull the pressure connection pad up from the frame, then work the ribbon out from the trench.
  9. LG K92 5G Screen Replacement, Extract Volume and Quick Action keys: 手順 9、 1の画像 1
    • Using tweezers or a bent pry tool, push the buttons out from inside of the frame.
  10. LG K92 5G Screen Replacement, Remove small components: 手順 10、 1の画像 1
    • Some small components like the vibration motor, antenna sticker, or earspeaker may need to be moved to the new frame.
  11. LG K92 5G Screen Replacement, Battery removal: 手順 11、 1の画像 1
    • Use a heating pad to warm the device from the front, apply generous amounts of alcohol to the battery compartment and carefully lift it out.
    • Avoid bending the battery as this can compromise the internal cells.
  12. LG K92 5G Screen Replacement, Install components in the replacement frame: 手順 12、 2の画像 1 LG K92 5G Screen Replacement, Install components in the replacement frame: 手順 12、 2の画像 2
    • Remove protective plastics from the replacement frame.
    • Reinstall components in the order in which they were removed. Be sure to align the antenna wires carefully to prevent pinching issues.
  13. LG K92 5G Screen Replacement, Finish it up!: 手順 13、 1の画像 1
    • Reinstall remaining components and tighten screws in their respective locations.
    • Always test the device prior to sealing the back panel on with new adhesive.
終わりに
作成者
2人の作成者と共同で作成されました。
Taptic Digital
メンバー登録日: 03/24/22
226 ポイント
1ガイドが承認済み
4 件のコメント
Why is there no reassembly guide?
Zach Benson - 返信
Follow the steps in reverse order.
Taptic Digital -
What is the black item adhered on top of the battery, with the connector!
JS1 - 返信
NFC coil, it is not a wireless charging coil despite being similar in appearance.
Taptic Digital -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 54
今までの合計 2,091
