メインコンテンツにスキップ
LG K7 Rear Facing Camera Replacement
必要な工具と部品
  1. LG K7 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 1 LG K7 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: 手順 2、 2の画像 1 LG K7 Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 1 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 2 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 3
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: 手順 4、 2の画像 1 LG K7 Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: 手順 5、 1の画像 1
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
James Ngo
メンバー登録日: 01/19/18
461 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S21G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 429
