メインコンテンツにスキップ
LG K7 Headphone Jack Replacement
必要な工具と部品
  1. LG K7 Headphone Jack Replacement, Battery: 手順 1、 2の画像 1 LG K7 Headphone Jack Replacement, Battery: 手順 1、 2の画像 2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Headphone Jack Replacement: 手順 2、 2の画像 1 LG K7 Headphone Jack Replacement: 手順 2、 2の画像 2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Headphone Jack Replacement, Headphone Jack: 手順 3、 3の画像 1 LG K7 Headphone Jack Replacement, Headphone Jack: 手順 3、 3の画像 2 LG K7 Headphone Jack Replacement, Headphone Jack: 手順 3、 3の画像 3
    • Remove the nine frame screws with a #J00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Headphone Jack Replacement: 手順 4、 2の画像 1 LG K7 Headphone Jack Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Headphone Jack Replacement: 手順 5、 1の画像 1
    • Line up a plastic opening tool underneath the headphone jack and hold the main body of the phone down.
    • Lift or the plastic opening tool to separate the headphone jack from the main body of the phone.
    • Be careful to not damage the components that the headphone jack sits in.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
James Ngo
メンバー登録日: 01/19/18
461 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S21G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 978
