メインコンテンツにスキップ
LG K30 Rear Facing Camera Replacement
必要な工具と部品
  1. LG K30 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 1 LG K30 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Rear Facing Camera Replacement: 手順 2、 1の画像 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Rear Facing Camera Replacement: 手順 4、 1の画像 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Rear Facing Camera Replacement: 手順 5、 2の画像 1 LG K30 Rear Facing Camera Replacement: 手順 5、 2の画像 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Rear Facing Camera Replacement, Motherboard: 手順 6、 1の画像 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Rear Facing Camera Replacement: 手順 7、 2の画像 1 LG K30 Rear Facing Camera Replacement: 手順 7、 2の画像 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Rear Facing Camera Replacement, Rear Facing Camera: 手順 8、 2の画像 1 LG K30 Rear Facing Camera Replacement, Rear Facing Camera: 手順 8、 2の画像 2
    • Only pry on the tab, not the connector itself.
    • Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
    • Remove the rear-facing camera.
終わりに
作成者
3人の作成者と共同で作成されました。
Vivek Kathrotiya
メンバー登録日: 02/26/19
735 ポイント
4のガイドは作成済み
チーム
Purdue University Northwest, Team S2-G1, Hingst Spring 2019 Purdue University Northwest, Team S2-G1, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S2G1
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 565
