メインコンテンツにスキップ
LG K20 PLUS Vibrator Replacement
必要な工具と部品
  1. LG K20 PLUS Vibrator Replacement, Remove the back cover and battery: 手順 1、 2の画像 1 LG K20 PLUS Vibrator Replacement, Remove the back cover and battery: 手順 1、 2の画像 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Vibrator Replacement, Midframe: 手順 2、 1の画像 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Vibrator Replacement: 手順 3、 2の画像 1 LG K20 PLUS Vibrator Replacement: 手順 3、 2の画像 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Vibrator Replacement, Rear-Facing Camera: 手順 4、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Vibrator Replacement, Motherboard Removal: 手順 5、 1の画像 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Vibrator Replacement, Removing the vibrator: 手順 6、 1の画像 1
    • The vibrator motor is held in with strong adhesive.
    • Insert the tip of a metal spudger on the right side of the vibrator motor and pry it upwards.
終わりに
作成者
1人の作成者と共同作成されました。
Patrick
メンバー登録日: 05/14/14
6,643 ポイント
21のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 8
今までの合計 278
