メインコンテンツにスキップ
LG K20 PLUS Motherboard Removal
必要な工具と部品
  1. LG K20 PLUS Motherboard Removal, Remove the back cover and battery: 手順 1、 2の画像 1 LG K20 PLUS Motherboard Removal, Remove the back cover and battery: 手順 1、 2の画像 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Motherboard Removal, Midframe: 手順 2、 1の画像 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Motherboard Removal: 手順 3、 2の画像 1 LG K20 PLUS Motherboard Removal: 手順 3、 2の画像 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Motherboard Removal, Rear-Facing Camera: 手順 4、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Motherboard Removal, Motherboard Removal: 手順 5、 1の画像 1
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Patrick
メンバー登録日: 05/14/14
6,586 ポイント
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 804
