メインコンテンツにスキップ
LG K20 PLUS Front Camera Replacement
必要な工具と部品
  1. LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: 手順 1、 2の画像 1 LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: 手順 1、 2の画像 2
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Front Camera Replacement, Midframe: 手順 2、 1の画像 1
    • Remove 11 Philips screws.
  3. LG K20 PLUS Front Camera Replacement: 手順 3、 2の画像 1 LG K20 PLUS Front Camera Replacement: 手順 3、 2の画像 2
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Front Camera Replacement, Front Camera: 手順 4、 1の画像 1
    この手順で使用する道具:
    Halberd Spudger
    $2.99
    • Use an opening pick or a Halberd spudger to disconnect the front camera flex from its socket on the motherboard.
    • The front camera is held in by adhesive. Carefully pry between the camera and its bracket on the frame of the phone to remove it.
    • If you're having difficulty removing the front-facing camera, remove the motherboard to make more room.
終わりに
作成者
2人の作成者と共同で作成されました。
Patrick
メンバー登録日: 05/14/14
6,643 ポイント
21のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 577
