メインコンテンツにスキップ
LG Incite Motherboard Replacement
必要な工具と部品
  1. LG Incite Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Motherboard Replacement: 手順 2、 1の画像 1
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Motherboard Replacement: 手順 3、 1の画像 1
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Motherboard Replacement, Back Panel: 手順 4、 1の画像 1
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Motherboard Replacement: 手順 5、 1の画像 1
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Motherboard Replacement: 手順 6、 1の画像 1
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 LG Incite Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 LG Incite Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
    • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
  8. LG Incite Motherboard Replacement: 手順 8、 1の画像 1
    • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
    • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
  9. LG Incite Motherboard Replacement: 手順 9、 2の画像 1 LG Incite Motherboard Replacement: 手順 9、 2の画像 2
    • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
    • Do not remove the tab completely, it should still be connected to the phone.
  10. LG Incite Motherboard Replacement: 手順 10、 1の画像 1
    • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
    • Lift the motherboard and slide it towards you by hand to free it from the phone.
    • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
終わりに
作成者
4人の作成者と共同で作成されました。
Kimberly Kha
メンバー登録日: 04/16/13
163 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G18
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 783
