はじめに
If your phone's camera breaks or you would like to update it, this guide will show you how to install your phone's camera.
必要な工具と部品
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
Locate the camera near the upper-left corner and use the metal tweezers to carefully detach the black tab.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
