メインコンテンツにスキップ
LG Incite CT810 Motherboard Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. LG Incite CT810 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 LG Incite CT810 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 LG Incite CT810 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Remove the four Phillips screws.
  2. LG Incite CT810 Motherboard Replacement: 手順 2、 2の画像 1 LG Incite CT810 Motherboard Replacement: 手順 2、 2の画像 2
    • With the screws set aside, wedge your plastic opening tool in between the screen and the case surrounding it. Gently move the tool along the edge to loosen the screen from the casing. Do this again on the other side as well. The screen and case won't be completely separate in this step.
  3. LG Incite CT810 Motherboard Replacement: 手順 3、 3の画像 1 LG Incite CT810 Motherboard Replacement: 手順 3、 3の画像 2 LG Incite CT810 Motherboard Replacement: 手順 3、 3の画像 3
    • Flip your phone over to the battery side. Locate the seam near the bottom of the phone between the plastic case and the metallic case. Like the previous step, wedge the opening tool into the seem, and slide it across. Then, pry the two pieces apart. Your phone should now be in two pieces.
  4. LG Incite CT810 Motherboard Replacement: 手順 4、 1の画像 1
    • Here is a top-down view of what your phone should look like. There are three yellow tabs that need to be loosened in order to remove the motherboard. The third tab is located underneath the speak/camera board in red.
  5. LG Incite CT810 Motherboard Replacement: 手順 5、 3の画像 1 LG Incite CT810 Motherboard Replacement: 手順 5、 3の画像 2 LG Incite CT810 Motherboard Replacement: 手順 5、 3の画像 3
    • The first two tabs are the easiest to remove. Take your metal tweezers and gently separate the white panel from the gray surface they are attached to. Do the same thing to the white panel on the other side of the phone (as shown in image 3).
  6. LG Incite CT810 Motherboard Replacement: 手順 6、 3の画像 1 LG Incite CT810 Motherboard Replacement: 手順 6、 3の画像 2 LG Incite CT810 Motherboard Replacement: 手順 6、 3の画像 3
    • To get access to the third tab, insert your plastic opening tool underneath the speak/camera panel, and gently pry at it. Do not fully remove the board though! It should still be attached to the motherboard by a red and black wire. Images two and three show the tab is red.
  7. LG Incite CT810 Motherboard Replacement: 手順 7、 2の画像 1 LG Incite CT810 Motherboard Replacement: 手順 7、 2の画像 2
    • To loosen this tab, use your metal tweezers to lift the side of the tab shown in image 1. You only need to gently lift it, it should pop off quite easily.
  8. LG Incite CT810 Motherboard Replacement: 手順 8、 3の画像 1 LG Incite CT810 Motherboard Replacement: 手順 8、 3の画像 2 LG Incite CT810 Motherboard Replacement: 手順 8、 3の画像 3
    • With all three tabs removed, its time to separate the motherboard from the other casing! Insert the plastic opening tool as shown, and gently pry the motherboard from its case. Make sure to do this on all sides before fully prying the two apart. The third image shows the motherboard on the left, and the second casing on the right.
終わりに
作成者
5人の作成者と共同で作成されました。
Matthew
メンバー登録日: 04/16/13
124 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S2G18
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 9
今までの合計 121
