メインコンテンツにスキップ
LG GizmoGadget VC200 Battery Replacement
  1. LG GizmoGadget VC200 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Pick any sides, and just wedge a flat pick to pop it open. Its held by gasket. I choose the top. work out well for me
  2. LG GizmoGadget VC200 Battery Replacement: 手順 2、 1の画像 1
    • Try to keep some of the gaskets on the right, some will be tangle up, you can cut those out. The pin connectors on the left, they are not glue down so if you drop them, just put them back
  3. LG GizmoGadget VC200 Battery Replacement: 手順 3、 1の画像 1
    • Use the pull tab to pull out the battery.. if it doesn't pull out, wedge something under it.. the one I had was pretty weak, pulled out easier.
  4. LG GizmoGadget VC200 Battery Replacement: 手順 4、 1の画像 1
    • Battery is out.
  5. LG GizmoGadget VC200 Battery Replacement: 手順 5、 1の画像 1
    • New vs old. Just bend the new battery connector similar to the old battery
  6. LG GizmoGadget VC200 Battery Replacement: 手順 6、 1の画像 1
    • From the old connector, transfer the double side tape and put it into the new battery
  7. LG GizmoGadget VC200 Battery Replacement: 手順 7、 1の画像 1
    • Place the new battery in and match the battery pigtail to the watch case. There are 2 dimples where you match to the pig tale. Once all the parts are secure, just snap the face back and do a test. Make sure everything still works, calling, texting, touch screen.
  8. LG GizmoGadget VC200 Battery Replacement: 手順 8、 1の画像 1
    • BL-S5 is the battery part number
終わりに
作成者
2人の作成者と共同で作成されました。
mikebuy78
メンバー登録日: 05/02/13
157 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 2,291
