メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will walk you through the process of replacing a dead or dying battery in LG GS170 cell phone.
  1. Turn off the the cell phone. Locate the the arrow at the top of the back cover. Slide the cover downward until the cover comes off.
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. Completely remove the back cover, and the battery should be visible. Locate the gap at the bottom right. Use your thumb to pop out the battery.
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
終わりに
ある他の人がこのガイドを完成しました。
Minna
メンバー登録日: 2014年10月08日
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-25, Donnelly Fall 2014 USF Tampa, Team 1-25, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G25
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 328
