メインコンテンツにスキップ
LG G8 ThinQ Vibration Motor Replacement
必要な工具と部品
  1. LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: 手順 1、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: 手順 1、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement, SIM Card Tray: 手順 1、 3の画像 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Vibration Motor Replacement, Back Panel: 手順 2、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement, Back Panel: 手順 2、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement, Back Panel: 手順 2、 3の画像 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Vibration Motor Replacement, Midframe: 手順 3、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement, Midframe: 手順 3、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement, Midframe: 手順 3、 3の画像 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Vibration Motor Replacement, Speaker System: 手順 4、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement, Speaker System: 手順 4、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement, Speaker System: 手順 4、 3の画像 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: 手順 5、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: 手順 5、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement, Headphone Jack: 手順 5、 3の画像 3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
  6. LG G8 ThinQ Vibration Motor Replacement, Battery: 手順 6、 1の画像 1
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  7. LG G8 ThinQ Vibration Motor Replacement: 手順 7、 2の画像 1 LG G8 ThinQ Vibration Motor Replacement: 手順 7、 2の画像 2
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  8. LG G8 ThinQ Vibration Motor Replacement: 手順 8、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement: 手順 8、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement: 手順 8、 3の画像 3
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
  9. LG G8 ThinQ Vibration Motor Replacement, Motherboard: 手順 9、 2の画像 1 LG G8 ThinQ Vibration Motor Replacement, Motherboard: 手順 9、 2の画像 2
    • Use an opening tool to disconnect the two coaxial cables from the motherboard.
  10. LG G8 ThinQ Vibration Motor Replacement: 手順 10、 3の画像 1 LG G8 ThinQ Vibration Motor Replacement: 手順 10、 3の画像 2 LG G8 ThinQ Vibration Motor Replacement: 手順 10、 3の画像 3
    • Using an opening tool, carefully disconnect the screen ribbon cable from the motherboard.
    • Using an opening tool, carefully pry up the motherboard from the frame and remove it from the phone.
  11. LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: 手順 11、 2の画像 1 LG G8 ThinQ Vibration Motor Replacement, Vibration Motor: 手順 11、 2の画像 2
    • Remove the vibration motor from the phone casing using an opening tool.
    • Heat the vibration motor from the other side of the phone to loosen adhesive if needed.
終わりに
Kristen Gismondi
メンバー登録日: 11/12/14
77,641 ポイント
184のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
16,253のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 304
