メインコンテンツにスキップ
LG G6 SIM Card Reader Replacement
必要な工具と部品
    • Insert wisdom here.
終わりに
作成者
2人の作成者と共同で作成されました。
MovilOne
メンバー登録日: 06/17/14
2,480 ポイント
11のガイドは作成済み
3 Guide Comments
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - 返信
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - 返信
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 6
今までの合計 4,384
