はじめに
Use this guide to replace a cracked or broken rear glass panel on your LG G6.
If your replacement part does not come with adhesive mounted on it, you will also need to purchase adhesive for the rear glass, rear button, and other small parts mounted on the rear glass. You can buy pre-cut adhesive, or thin high-bond tape.
In the following steps you will be cutting through the adhesive on the rear glass panel.
Take note of the following areas:
In addition to cutting around the edge, there is extra adhesive here that should be cut.
Avoid sticking the spudger blade in too far here, to avoid damaging the rear button ribbon cable and chip.
Use the opening picks to slice through any remaining adhesive and open the phone.
Remove the glass from the phone.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
24 の人々がこのガイドを完成させました。
コメント1件
Spend the extra couple $s to get well sourced products.
For the LG G6, chuck any adhesive for the rear glass provided in the garbage. It'll be too thick, use ifixit Tesa 61395 tape to make yer own seal.
The fingerprint sensor is very sensitive to these small clearances. I put a piece of Tesa 61395 between the plastic lense cover and contact plate for sensor.
Now I've got a great seal and perfectly working sensor. Thanks ifixit!
