はじめに
This guide will show you the steps to replace a damaged rear facing camera.
必要な工具と部品
While holding the battery release button, pull the bottom end of the phone out of the body.
Insert the plastic opening tool into the seam between the glass screen and the metal body.
Pry the glass from the body only a slight amount.
It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
Insert the Spudger into the now open space between the body and screen.
Push inward to separate the screen even more.
Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
My LCD started to let loose using this way to saparate the top and bottom of the phone.
I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
Yep! I did it also with this method. Wayy better and easier ;)
I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
After detaching the ribbon, carefully remove the camera using tweezers
The camera is attached to the frame with adhesive- use a nylon screen opening tool or a spludger to help lift the camera off of the body. Tilt it out at a 45 degree angle to clear the PCB and you're ready for replacement!
I found it easier to use some guitar picks to separate the screen from the body. I lifted the screen away from the body using a prying tool, then insert the guitar pick in the gap. I worked it along the seam until I got to the top of the phone, then worked on the other side.
34 の人々がこのガイドを完成させました。
6 件のコメント
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
I can’t pry the screen off with the plastic tools I purchased with ifixit. what now?
